[Warning Light] Side impact sensor for airbag, fault.
Hi there!
My first post at this forum.
My 2007 1,6 (90 hp) diesel Berlingo is showing the airbag warning light.
I had done a scan at a nearby garage.
I was told the error code was  211 and had something to do with configuration of side impact sensor at the passenger side.
My questions are:
Does my car have this sensor?
If so, where is it located? Inside the door?
I could not find any reference to code 211 in any discussions at the web, including this forum. I suspect I have been given the wrong code from the garage. (Normally there is a letter in these codes, I have noticed.)
I belive I have done the basics, checked plugs under seats, plugs at the airbag controlunit under the mid console, the passenger airbag-switch, and the BSI reset a few times. So any experience from you guys would be very welcome. Thanks.
usually a four or five  figure number for a fault code with a code letter eg P for power train, B for body , C for chassis an U for wiring, canbus.
If its a airbag fault code then it should begin with B or U
I think you've been given the wrong or incomplete code .
Try a generic scanner which are quite cheap (elm 327 ) and can be run on a mobile or find someone with lexia or try another garage.
Found  a code for U 0211   " Lost Communication With "Seat Control Module D" " .
Which may be the wiring in or under the seat, earlier models had problems with the wiring connectors under the seats. Check the connections under the seats.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(14-12-2021, 07:25 AM)brodfather11 Wrote:  usually a four or five  figure number for a fault code with a code letter eg P for power train, B for body , C for chassis an U for wiring, canbus.
Thank you brodfather11!
I have ordered my OBD code reader today. I assume even if I would manage to find and fix the problem without the ELM 327, I still would have to return to a garage for another 100 USD clear-code-job. So a 10-15 USD device would be worth a try.
I will check the connectors under the passenger seat again, before doing anything more timeconsuming.
Yesterday 02:50 PM
Yesterday 02:31 PM
Yesterday 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
