14-12-2021, 06:49 PM
The off side rear wheel bearing on my van is "rumbling". There is no excess play just the rumbling noise when the wheel is rotated.
Searching the internet it appears replacement bearings are available for as little as £16/£17. However a replacement wheel bearing kit to include hub are available for around £30. To me the replacement kit including the hub is a no brainer as it saves trying to find someone/somewhere to get the old bearing pressed out and the new bearing pressed in.
My query is and I might be slightly dense here
but internet searches are listing two options for my van. 1 with ABS and 1 without ABS, I understand the difference is the reluctor ring on the hub......................but how do I find out if my van has ABS to ensure I order the right one?
Many thanks in anticipation
