Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Noticed today that water is coming in from around the bottom of the door card. The factory fitted liner is knackered, so is there another way to stop the water getting in.
Looking at the factory fitted one its made of foam and sticks to the inside of the door and its at the bottom where water has settled over the years the the adhesive as become shot.. Can one be fitted inside the door so water has no where to settle?
Threads: 63
Thanks Given: 410
Can't you make a new one from a sheet of thick polythene or similar? unfortunately the liner is an essential part of keeping the water from out of the car. Did a similar daft trick with my 306 and that used to pee in..
Threads: 12
Thanks Given: 31
Have done, used gaffer tape to tape it to the door, but water is passing this now. Whats best to stick membrane to the door with?
Threads: 63
Thanks Given: 410
(29-01-2012, 12:18 PM)800HDI Wrote: Have done, used gaffer tape to tape it to the door, but water is passing this now. Whats best to stick membrane to the door with?
Probably a continuos bead of silicon sealant to bed the plastic on ???
