Thanks Received: 1 in 1 posts
27-12-2021, 05:12 PM
(This post was last modified: 27-12-2021, 08:31 PM by Beanbrain.)
Evening all. My 2003 Berlingo has both Airbag lights on the car came too me with these on. Reading through posts etc I’ve looked at some of the wires and it would appear a previous owner has had fun with them too. Lots of cut and shut cables. I’ve pulled off the electrical tape off all the joints I could find and all seem to be making contact.
After advice what to check and how to check. Hopefully having both on it will point to something.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
Is there any problem with the ABS or is that just a typing error in the title of the thread?
Threads: 8
Thanks Given: 305
37
27-12-2021, 09:58 PM
The plugs can cause a bad connection so some people cut them off and join the wires, sounds like that is the case with yours.
Getting rid of the plug and joining the wires normally cures any problems, how are the wires joined, twisted together, in a connector block, or soldered?
Threads: 8
Thanks Given: 305
37
It sounds like someone has had a good go at it, hopefully you will be able to reconnect any cut wires & solder the others to solve the problem.
Let us know how you get on.
Thanks. Will do. If I don’t get it sorted the. It’s scrap. Not worth paying someone to fix…. Engine solid etc not too bad as it goes but not worth investing
Been through everything visible and cjf moe everything is connected. I still have both airbag lights on ?
Threads: 123
Thanks Given: 250
34
Have you had a look at the OBD error codes, maybe they can be reset? Lexia would maybe give more info too.
Hi don’t have access to anything.. the cheap OBD readers don’t look at airbags
