Time and date fault
Hello all,
I have a fault with the time and date on the centre display,
The time and date doesn`t stay as is set, using the menu/nav controls on the CD radio,
each time the ignition is turned on,
the time resets to 0:00
and the date returns to "1 JAN 2007"
Any ideas what may be the fault
Regards
2018 B9 1.6HDIblue 625LX
Does it turn on when the ignition is off ?
(29-12-2021, 08:57 PM)OMG Wrote:  Does it turn on when the ignition is off ?
Yes,
The radio can be turned on and the time/date be set with the ignition off.
Would seem the constant live is there so would say the fault is in the set. Maybe time for a upgrade!
[-] The following 1 user says Thank You to OMG for this post:
  • An islander
(29-12-2021, 11:24 PM)OMG Wrote:  Would seem the constant live is there so would say the fault is in the set. Maybe time for a upgrade!
Thanks OMG,
by saying the set, do you mean the display unit?
Hmm thinking about it try resetting the clock and disconnect the stereo. If it stays ok then maybe problem in stereo? and if it resets then it’s the display. Kinda winging it here just trying to think of away of troubleshooting it. THe fact that it loses the time means the live to wherever the clock is lost. This post will give you the idea. https://frenchcarforum.co.uk/forum/viewt...hp?t=63248
If the problem is the only thing wrong must be wiring problem in unit or display. Probably display. Not sure if I am helping here or not! ? Good luck
(30-12-2021, 09:01 PM)OMG Wrote:  Hmm thinking about it try resetting the clock and disconnect the stereo. If it stays ok then maybe problem in stereo? and if it resets then it’s the display. Kinda winging it here just trying to think of away of troubleshooting it. THe fact that it loses the time means the live to wherever the clock is lost. This post will give you the idea. https://frenchcarforum.co.uk/forum/viewt...hp?t=63248
Thanks,
I`ll look into the post.
looking into the fault I see that the shunt,SH, fuse is in the `parking` and not the `client` position.
i wonder if the fuse should be in the `client` position. as I understand from the previous owner this fault present from new
Am not familiar with what that is. The thread does seem to indicate that. Can you try it to see?
Today 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
