Three Beeps/Tunes when getting out of vehicle
Hello,
When i take the key out of the ignition i get three beeps/tunes. This only happens when the key is taken out of the ignition. Has anyone experienced this before or know what the cause is?
Mine does it too, and it also does it when I turn the ign on.
The only fault I currently have is that the speedo and mileometer are not working (local mech could not find the fault so I must travel to a Citroen specialist some time).
I assumed the beeps were to do with that, but don't know for sure.
Just to check we're on the same page, and for others' benefit, my beeps are exactly the same as the seven (?) beeps you get if you take the key out with your lights still on.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
(06-01-2022, 02:33 PM)Rasputin Wrote:  Mine does it too, and it also does it when I turn the ign on.
Hello. This happens when you take the key out even with the door still shut. The lights beep when the door is open. The beep is slightly different to the lights beeping.
Yesterday 10:15 PM
» Replies: 41
What is this?
Yesterday 07:23 PM
Iceland Trip and modifications
Last Post: Vantour Berlingo
Yesterday 06:05 PM
Engine judder at 1800 rpm
Last Post: rodthemod
Yesterday 04:58 PM
Heater blower not working
12-09-2024 12:22 PM
Key.... repaired... but how much for a New fob
Last Post: Gadgetman
12-09-2024 08:19 AM
Correct FAP Tank? 2012 plate L2 van
11-09-2024 11:34 AM
High Beam LED upgrade possible? YES
10-09-2024 10:31 PM
ABS Sensor Fault M59 1.6HDI
Last Post: BaysideM59
10-09-2024 08:42 PM
Knocking sound from front end when going over ro...
Last Post: markscotford
10-09-2024 08:04 PM
