towbar wiring
hi folks, i have a 2014 multispace plus and i pick up my new towbar at the weekend. Can i use normal trailer electrics with a bypass relay or does it need to be dedicated wiring? thanks.  Huh Shy
I will tell you next week. Mine (for my 2013 Te3pee Outdoor) was delivered today, and I will be fitting it later this week. I found a detailed talk-through on here and printed it off. Whoever wrote it found that the universal wiring kit with bypass worked without needing coded afterwards.
And to whoever wrote it - many thanks.
[-] The following 1 user says Thank You to unclealec for this post:
  • Davymcd70
(11-01-2022, 05:04 PM)unclealec Wrote:  I will tell you next week. Mine (for my 2013 Te3pee Outdoor) was delivered today, and I will be fitting it later this week. I found a detailed talk-through on here and printed it off. Whoever wrote it found that the universal wiring kit with bypass worked without needing coded afterwards.
Sounds great bud, thanks. I will look for the talk through you mentioned ?
Yur tis
https://www.berlingoforum.com/thread-185...PpzC19Kb9s
Thumbs Up
Thankyou for the link
OK - report. Instruction 1 - remove lower bolts holding bumper assembly to chassis. First bolt I tried sheared off! Forunately I was able to heat the threaded boss red hot and wind the remains of the bolt out "the wrong way". But from there onwards it practically flew on. I bought from eBay and am very happy so far. Universal wiring kit to fit tomorrow - another report after. https://www.ebay.co.uk/itm/160633345601
[Image: xyTL8ZO.jpg?1]
Yesterday 04:48 PM
Last Post: BrianS
Yesterday 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
Yesterday 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
2011 B9 DPF warning light
22-01-2025 10:51 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
