Can I dirll a Holes in this area?
(Borrowed picutre from the internet)
I wish to put 2/4 SS M6or8 rivinuts in this area, is it safe enough to drill there or am I asking for trouble?
The purpose is to secure a jerry can in that area (10/15L water). I'd hoped they'd be some tie down point or existing bolts but it seems lacking anywhere to tie into/bracket off. There is the right hand anchor point but its not quite where I need it to be.
If you remove the black blanking plugs you may be able to see into the area where you want to drill your holes. If not then feel with you hands .
I think you'll be OK because you are drilling above the tyre line and into a space where a rivet nut will not interfere with anything . Be gentle when you drill and don't hit the inside of the outer panel.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • smtk
Isn't the fuel tank in that general area?
I think you'll need to take a look under to verify.
Thanks for the replies. I'll have a look once its back, Atm the cars away having a new ball joint and a full serviced they were short staffed yesterday didn't manage to get it all done before closing.
Last Post: Alberts elbow
Today 10:11 PM
Today 09:32 PM
Today 05:46 PM
Today 05:17 PM
Potential Purchase!
Today 03:03 PM
Diagbox 7.57 download
Yesterday 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
