Berlingo M59 1.9D mind of its own
Hi
I've recently acquired a 2006 Citroen Berlingo 2006 1.9D 600 VAN, and it has an after market cut off switch that cuts power to the BSI module, when the switch is on the side lights stay on and central locking doesn't work and the dashboard lights up like a Christmas tree, if I do the BSI reset normal service is resumed as in everything works as it should, central locking no crazy dash lights and the side lights stay off. When I leave the car for approx 5 minutes locked with no keys, it automatically decides to turn the lights on, kill the central locking and light the dashboard up like a christmas tree (even with no keys in it) could this be the dreaded BSI module?
If it is the BSI module how do I remove it?  I suspect it is as the cut off switch has been inserted in a large red cable that looks like it goes to the BSI module (drivers side inside the car).
Kind Regards
Aaron.
It sounds like someone has fitted the battery kill switch to cure the problem and created another by wiping the BSI memory when it is switched off. Is the crazy happening after you have reset the BSI then left the car switched off with the battery still connected ?
2015 Berlingo van for sale
Last Post: eddyale
Today 06:47 PM
Last Post: deejay_xb
Today 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Today 01:48 PM
Unusual Braking Problem
Today 07:52 AM
valeo alternator CL15 rebuild
Today 07:49 AM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:08 AM
