Threads: 9
Thanks Given: 28
19-01-2022, 11:50 AM
(This post was last modified: 19-01-2022, 11:51 AM by pavb2.)
Hi all neither the front or rear windscreen washers are working. I can’t hear the pump when I operate the steering wheel stalk. Before I start trying to fix can anyone point me in the right direction as to where the fuse box is, which fuse to check and anything else that might be the problem.
Many Thanks
Threads: 75
Thanks Received: 1,303 in 1,140 posts
Thanks Given: 223
163
19-01-2022, 12:02 PM
(This post was last modified: 19-01-2022, 12:02 PM by Sol.)
The fuse is 10A number 3 or 4 in the engine bay fuse-box but it will be the infamous washer pump failure, located behind the drivers wheel arch liner, towards the front. Reuse the rubber seal between washer bottle and pump, and remember to get the twin outlet model. These are under £20 from Amazon and pretty much blueprints to the original.
I'll dig out my fuse diagram and tell you for sure but I would bet my last tenner you are on your way to fitting a new pump.
• pavb2
Threads: 75
Thanks Given: 223
163
• pavb2
Threads: 75
Thanks Given: 223
163
Excellent news, glad to hear it was only the fuse.
