Hope I don’t regret this impulse buy?
I Just got a multispace 2.0hdi, 2005. Has some issues and I paid more than I should’ve. But I wanted it.
Had one years ago and was the best, most reliable and versatile car I ever had. Now bought this old one after making do with an xsara then a Skoda.
Now I need to sort a slow starter, floppy gearstick, seized spare wheel bracket, noisy wheel bearing, broken wing mirror, defunct glow plugs and dash illum bulbs. And needing to fit a tow bar.
Oh well..
Berlingo Multispace Forte, 2.0hdi, 2005.
Steel wheels are better than alloys.
Welcome. Sounds like you have plenty to do, the good news is that all of your jobs have posts on here with info.
Hello and welcome !
Other than tow bar £200 MAX should sort it all ( DIY )
I had the spare wheel problem when I first got our car. I sorted it by jacking the carrier up with a trolley jack and forcing the hook off then plenty of penetrating oil and once it moves keep it greased
£200 sounds good to me. Mechanic is going to do the wheel bearing and front brakes for £250. The rest I’ll do myself.. with help from YouTube and info found on here.
Glow plug actually works- just found out it has to be cold. Came on for about 1 sec this frosty morning. So need to research this further.
Parts are ordered, tool box ready.
If it ain’t broke, i ain’t gonna touch it!
The dash glow plug light is a poor indicator of what the glow plugs are doing.
The glow plugs normally come on for a pre heat prior to starting when the temperature is around 7℃ or lower., once the engine is started they stay on for around 3 minutes (post heat) to aid smooth running and help reduce emissions until the engine warms up a bit.
(22-01-2022, 09:13 PM)jj9 Wrote:  The dash glow plug light is a poor indicator of what the glow plugs are doing.
Thanks- that’s helpful to know. My engine turns too slow on the key. After spinning for a few seconds it speeds up a bit and then it will start. Put a new battery in and checked the earth strap. But I’ll test the plugs first to see if they’re actually working. And if they are, a new starter may be the next step.
A slow starter which gets quicker is almost certainly the starter brushes if the battery is in good condition. It was the first thing that I had to fix on my 2.0. Choices are changing the brushes or a new starter motor. There are a lot of posts on here about uprated starters. I put a new set of brushes in mine, cleaned the commutator & never had any problems after. There's a good video about it on YouTube somewhere. I think the cost differences were about £20 vs £80 but it was a while ago.
  • JasonJ
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
