23-01-2022, 11:17 AM
Hoping someone might be able to help.
I have an indicator issue:
When indicating left, I noticed that occasionally the green light on the dash went quicker (like when a bulb is out). Not every time, but occasionally (an intermittent fault).
Eventually, it became a pernament fault, and the rear N/S indicator stopped working.
Thinking it was a blown bulb, I replaced that with new. The problem wasn't resolved.
I inspected the bulb holder, and noticing a small amount of corrosion inside the wiring connector I replaced the bulb holder. Still didn't fix the problem.
I then figured maybe the connector plug might also be corroded, so I ordered and fitted a new connector. Still didn't fix the problem.
After some further research, I learned that the BSI might need resetting. So, I did that, and the problem still exists.
The odd part is that when I lock the car and arm the alarm, all indicators flash, even the one that no longer works with the stalk.
I'm in Cornwall. If anyone is local or knows anyone local with a lexia or similar to diagnose and locate/ reset the fault please get in touch.
If anyone on here has had a similar/ same experience and has any suggestions I might try I'd appreciate your suggestions.
