Reverse light cable
I have been studying the Haynes manual wiring diagrams.
My brain hurts.
Could some guru with a better understanding of these things tell me what colour cable supplies power to the reverse lights on a 2013 Partner Tepee Outdoor?
It doesn't have a reverse warning bleeper system and while I am installing a towbar I want to fit an aftermarket reverse warning sensor device. I have the rear light clusters out and the trim panels off the rear inside quarters.
There should be numbers printed on the wire , Colours are sometimes random
The mulitplugs at the light clusters have or supposed to have, numbers on them . ie brake light is wire number 2100 in plug position 5 (r/h)
I think the wires you want are 2201 or 2202 at plug position 1,
Best check with a multimeter with ignition on and in reverse gear
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • unclealec
Hey, thanks Brodfather111! Every day a schoolday!
I had actually noticed the printing on the cables but totally failed to realise their significance.
I come from the land of Joseph Lucas Prince of Darkness, where all I have to contend with is green red, white, blue, brown, and smoke.
Last Post: LucyLeBingo
Yesterday 02:42 PM
Yesterday 02:30 PM
Last Post: jw4821
Yesterday 12:53 PM
Coolant
Last Post: tomhick024
19-04-2026 06:18 PM
SOLVED: P20F6 fault
19-04-2026 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
