Threads: 2
Thanks Received: 1 in 1 posts
Hi, Folks
what is the metal plate that screws across the end of the torsion bars called? I believe it has a loop bent over to clip the handbrake cable to.
Are they available new?
Mine have dissolved on the salty Scottish winter roads.
Threads: 8
Thanks Given: 305
36
Threads: 8
Thanks Given: 305
36
Yeah I see the bracket you mean, I can't see it on any of the cat car diagrams either
Threads: 2
Aye, it is strange, not the end of the world, I can make something, but it seems odd that they are not listed.
Thanks for your responses, though.
Threads: 5
Thanks Given: 4
21
Can you possibly use a stainless P clip - the sort that has a rubber liner - attached under one of the cap bolts ?
Alternatively make a strip with a P shape bent at the free end and drill a hole in the other end for the bolt. There's little stress on the 'loop' and it's probably there to anchor the cable to avoid chafing?
Threads: 2
Aye, have plenty of rubber lined P clips, can whack one on the end of the clamped torsion bar.
Thanks for all the responses.
