Tailgate trim removal
Hi.
I need to remove the black plastic trim above the rear number plate, does it pull off or do I need to remove the inner tailgate panel to access the any retaining screws?
Thanks.
This should cover it ...https://m.youtube.com/watch?v=r3jYokM3kWA
(03-02-2022, 05:30 PM)oilyrag Wrote:  This should cover it ...https://m.youtube.com/watch?v=r3jYokM3kWA
That's the earlier Berlingo model, so I'm not sure if the clips will be the same as mine.
Looks like its held on with nuts
http://www.catcar.info/citroen/?lang=en&...aWVyPT0%3D
Thanks for the link.
It does look like it is held with nuts, two, one at each end?
I don't want to remove the inner tailgate cover as I'll probably snap off most of the clips that hold it, so I might look at drilling a hole in the plastic cover from the inside and see if I can get a socket in the nuts.
I'd watch for hitting wiring doing that. Those clips would prise up with a teaspoon, they are fairly robust. The rest of the panel will pop off with a soft lever, something like a window scraper
Trim removal tools are the way to go - the idea is to apply equal lifting pressure to both sides of the clip so that it doesn't break. For example:
https://www.ebay.co.uk/itm/203741660151
Or for a bit more dosh:
https://www.ebay.co.uk/itm/144248266672
Plus I'm sure that you can get replacement clips just as easily.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
[-] The following 1 user says Thank You to Gryffindor for this post:
  • notsofast
I have trim removal tools and they're the best things ever. I just know a lot of folk don't bother getting them but Gryff is right, they are well worth it.
Plus, the clips are as cheap as chips, it is worth having some in stock.
Peter
This video shows removing the B9 inside trim and outside handle. No less than six nuts for the handle trim.
From 2:22 onwards:
https://youtu.be/ELZaFBxEKGM
[-] The following 1 user says Thank You to Drummond for this post:
  • smtk
Gearstick has play
Last Post: marzzden
Today 04:35 PM
Last Post: BrianS
Today 12:56 PM
» Replies: 22
Pling sound when door open
Last Post: Mark604
Yesterday 07:52 PM
Hello
Last Post: Pricklybuzzz
Yesterday 07:08 PM
Fuel Gauge trouble
Yesterday 10:44 AM
2011 B9 DPF warning light
18-01-2025 11:52 PM
Any advice regarding boot carpets being wet!?
18-01-2025 05:50 PM
» Replies: 21
18-01-2025 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
