Threads: 2
Hi,
I'd like to introduce myself - walnutfarmmick - and my 2003 2.0 HDi van. This forum was recommended to me by a friend ( that I spar with but don't actually know ) on another forum when I was seeking help regarding my rear axle. I was sure the problem must have arisen before, judging by the number of knock-kneed vans I see about, though I haven't spotted it in the past threads. Does anyone know for sure if I can fit the axle from a Mk I van ?Neither axle has disc brakes.
Thanks in advance, Mick
Threads: 32
Thanks Given: 24
Thanks for letting us know, it's appreciated and adds to the pool of knowledge from which we can all benefit.
Hope you stick around - you never know, you might find another sparring partner on here !!
Threads: 15
Thanks Received: 26 in 17 posts
Thanks Given: 25
Location: Blairgowrie, Perth And Kinross, United Kingdom
Hi Mick,
At my work, the roads engineers run around in Peugot Partners of various vintage (52 plate onwards) and most of them have had to have the rear axles replaced due to the bearings wearing out and causing the wheels to splay. In some cases the axles have more or less reached the point of collapse. Mechanics reckon if a grease nipple had been fitted to the bearings and bushes the problem would be solved. I have a 56 plate Berlingo 1.9 Enterprise which seems to be ok so far(14500miles). I tried asking about this problem on the forum previously but no one had come across it before. It appeared to only occur to the Partners but possibly now affecting the Berlingos.
Threads: 50
Thanks Given: 743
Quote: " It appeared to only occur to the Partners but possibly now affecting the Berlingos."
They're the same vehicle! A grease nipple is not hard to fit as an 'extra' although you require w/shop
facilities. Once the axle is stripped down a drilled and tapped hole and a new nipple is all you need.
I think it can also be done with axle in situ if the bearing have been removed.
Threads: 3
I've just had this problem on my 05 Berlingo. I noticed a little while ago that the van was looking a little knock kneed so thought I'd check it out when the weather improved. Last week the torsion bars snapped. After pulling it all apart at the weekend I fount that the needle bearing on the axle/swing arm had all but disintegrated. The axle the bearing runs on is destroyed by corrosion and and my only option is a new rear axle assembly. Be warned, up until i noticed the wonky wheel the van gave no signs or noises to indicate there was a problem.
Will hopefully be replacing the axle this weekend. Can anyone offer any advice or tips or even better diagrams on how to do this.
Cheers all.
Threads: 19
Thanks Received: 18 in 11 posts
Thanks Given: 21
Our 2001 car needs a replacement axle - we're hanging on in there for the moment though!
Threads: 5
Thanks Received: 76 in 45 posts
Thanks Given: 19
24-04-2012, 07:34 PM
(This post was last modified: 24-04-2012, 07:35 PM by BlueBlingo.)
(24-04-2012, 09:58 AM)TwIstedSpanner Wrote: I've just had this problem on my 05 Berlingo. I noticed a little while ago that the van was looking a little knock kneed so thought I'd check it out when the weather improved. Last week the torsion bars snapped. After pulling it all apart at the weekend I fount that the needle bearing on the axle/swing arm had all but disintegrated. The axle the bearing runs on is destroyed by corrosion and and my only option is a new rear axle assembly. Be warned, up until i noticed the wonky wheel the van gave no signs or noises to indicate there was a problem.
Cheers all.
Follow this link
http://www.berlingoforum.co.uk/forumdisplay.php?fid=12
Download M59 and you should have all the information you need.
2003 Citroën Berlingo 2.0HDi Multispace Desire
Thanks Given: 1
Hi Axle Removers - "Haynes says" I will need new hubs on my replacement 2004 HDi MultiS rear axle. This correct?
