29-01-2012, 09:10 PM
hi all, new to this site, hope some of you can help me .
i have recently purchsed a berlingo 1.6hdi 07 plate with 60000 milew.
its started giving off a whine from the front, which i thought was a wheel bearing as when i turned a corner the whine was louder.
changed the bearing and the whines still there.
, i have been under the van and cannot seem tho find out where its comming from.
i took it to a local garage and they said it needed two front wheel bearings even tho i told them that i had one side done already and the noise was still there.
could it be comming from a drive shaft?
is it common for the wheel bearings to go with 60000 miles on it???
any advise would be much help.
p.s. noise still there when out of gear and cluch depressed.
cheers
michael
, i have been under the van and cannot seem tho find out where its comming from. i took it to a local garage and they said it needed two front wheel bearings even tho i told them that i had one side done already and the noise was still there.
cheers
michael
