Engine cut out
Hi, driving my berlingo Multispace 1.6 turbo diesel, with no warning the car suddenly lost all power and the orange engine management light came on. After ten minutes the car started again and thankfully I got home. However; having left it overnight it now shows the onange light and refuses to start.  Can anyone help me please.
Unfortunately there could be a wide range of reasons for the issue and the light coming on. The fault will be recorded as a code and you'll either need to buy a code reader to see what codes are there or get a garage to read the codes. Once you have the codes then post on here again and there's sure to be someone who can identify what each one means. Alternatively if you have AA Homestart or similar then call them out as they'll use a code reader to identify the issue. Make sure you note what the problems are!
Good luck.
  • Nanny
Just looking for a code reader now which one do I need OBD2 ?
(14-02-2022, 04:36 PM)oilyrag Wrote:  Unfortunately there could be a wide range of reasons for the issue and the light coming on. The fault will be recorded as a code and you'll either need to buy a code reader to see what codes are there or get a garage to read the codes. Once you have the codes then post on here again and there's sure to be someone who can identify what each one means. Alternatively if you have AA Homestart or similar then call them out as they'll use a code reader to identify the issue. Make sure you note what the problems are!
Good luck.
Just looking for a reader now, any idea which one I need an OBD11?
Good luck.
Good question. I have bought a few of these down the years. It is a hit and miss with the cheap OBDII adapters and unfortunately cannot recommend one, maybe someone else will advise on a working one. Most of them do not work with an iphone (something PSA specific), but should work with android ones.
[-] The following 1 user says Thank You to saskak for this post:
  • Nanny
It's OBDII or OBD2, the reader connects to an android phone app (normally Torque) via bluetooth.
Here's an example, but there are many more. There will be some recent posts on which ones people have bought, a search for 'obd' will bring a few results:
https://www.ebay.co.uk/itm/384209355750?...SwbcVgvdnc
  • Nanny
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
