Front Wiper Arms
HI, I have a 2002 berlingo M59and it has 2 Front Wiper Arms but they are different length and I don't know which arm goes where, can anyone please help me.
I've replied to you on this one before! https://www.berlingoforum.com/thread-219...=wiper+arm
the crank arms look the same
Passenger side around 24" long from locating nut to blade 'hoop',  drivers side around 20".
is the wiper blade meant to touch the rubber window at the top of the windscreen on the passenger side?
because mine does.
No, but it could simply be that you've the wrong blade fitted to that arm.
The blades are sometimes listed as drivers side & passenger side as though there might be a difference, but I've always fitted 'pairs' of the same length from folk like Lidl. From memory 21 or 22".
both blades are 22" as said by Citroen car dealership
Sounds about right, so either your arms are too long, or maybe cranked ones have been replaced or they have not been set in the correct parked position and this has changed the swept arc.  If they are parking pretty much level at the bottom of the screen and are 20" and 24" then the simple option is to fit shorter blades.
thanks
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
