  • 1 Vote(s) - 2 Average
Suspension Ball Joint
Hey guys, my steering wheel has gone off centre and I thought it must be the tracking. Had it done at the local garage.
However took it back thinking they hadn't done it correctly as the steering wheel was still on the wonk...turns out the OSF Suspension Ball Joint is badly worn and needs replacing. This is causing the crooked steering wheel apparently??
How simple is this? Is it a push in fitting or bolt on?
Any part numbers for what I'd actually need??
Ever grateful...as always  Big Grin
My little beauty...2009 M59 Peugeot Partner 1.6hdi (90bhp)
It fits into the bottom of the front strut/wishbone, this will give an idea what it looks like - https://www.ebay.co.uk/itm/174157669231?...OSwHZNiDPO-
It's not too difficult, if you have the right tools/jack etc.
  • LukeClark
Thanks very much, that's really helpful
Best identify what type of suspension control arm (wishbone) is fitted to your Berlingo as there are two types, a pressed steel version that has a riveted or bolted on ball joint like in the link oilyrag posted, and a cast steel version where the ball joint is part of the arm and isn't replaceable, (the whole arm will need to be replaced)
If you have the pressed steel version and the ball joint is riveted in place you will have to drill out the rivets which can be an awkward job, the replacement ball joint can then be bolted in place.
Best buy a Haynes Manual is my advice, sorry if it sounds harsh but meant in the best possible way.
Sourcing a part ( part number ) .. just ask for the part in your local Motor Factors they will have it as they will be supplying the local motor trade, price will be competetive.
As geoff says, give your local motor factor your reg and possibly your VIN and the will source the correct part. I wouldnt waste your time with a new ball joint, better to fit the whole are as the rubber bushes wear and ther isnt a lot of difference in the price.
Peter
As JJ9 says, there are 2 different parts.
It may be worth having a look on Catcar using your VIN
http://catcar.info/citroen/?lang=en
I did both mine for the MOT.
Cost a fiver each from ECP.
Quite easy, but dont pull the driveshaft out of the gearbox Shy
Last Post: rom4ik
Today 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
