Threads: 6
Thanks Received: 1 in 1 posts
Thanks Given: 3
18-02-2022, 09:19 PM
(This post was last modified: 18-02-2022, 09:20 PM by Nanny.)
Hi guys hoping you can help again. Hubby has changed the fuel filter on my 2006 1.6 tdi and has primed it until his fingers nearly dropped off, but it still won’t start ? he has drained two batteries and is getting rather cross. Any ideas on what to do would be welcome. Thanks
Threads: 8
Thanks Received: 431 in 386 posts
Thanks Given: 248
22
The one way valve in the priming bulb may not be working correctly, can you notice the bulb getting firm after priming for a while or does it always just feel the same.
If there's no difference in feel you may have to remove the filter and fill it with fuel.
You could try the old trick of spraying easy start or carb / brake cleaner into the intake to get it to fire which can help pull the fuel through.
Threads: 4
Thanks Received: 135 in 131 posts
Thanks Given: 3
13
Certainly as above and also check that the filter and seal are correctly seated and the cover sits down well - air leak will allow fuel to drain back into the tank.
Threads: 51
Thanks Received: 655 in 554 posts
Thanks Given: 138
42
I'd remove it and start again from scratch.
On my 1.6 Hdi there is a portion of the filter that is swapped over onto the new one.
I use Mahle filters and these come with new O Rings in the box, did your filter come with some ? if so did you fit them to the new filter ?
Anyway I'd remove and refit in case you have a bad joint.
My primer located horisontally behind the engine pumps away and you can hear the fuel being moved around and whilst it firms up a little it never gets any firmer.
By the way there is a plastic screw on the top of the filter ( on mine ) maybe worth checking it is screwed down fully.
Threads: 6
Thanks Given: 3
Thanks everyone, he’s going for take two??
Threads: 51
Thanks Given: 138
42
Take two is the best approach to begin with as it is free of cost and may provide a cure, it would be a shame to pay a garage when there is no reason, it is likely a mechanic in the garage would fit a new filter to provide a known datum to start from. As I say why pay twice if you don't have to.
Threads: 6
Thanks Given: 3
Thank you all did a take two but it was still the same? friend just plugged it in reset the brain and it started first time ? it’s running as it should now however; after stoping and restarts the light has come back on ? do you think it will clear itself or will I have to have it reset again ?
Threads: 51
Thanks Given: 138
42
Try another reset first you may be lucky.
Can the friend read the fault code ?
Threads: 6
Thanks Given: 3
Thanks I’ll ask him to do another reset when the weather improves, it’s vile out there? think I’ll get hubby to change the cam sensor in the mean time can’t do any harm hey ??
Threads: 39
Thanks Received: 358 in 317 posts
Thanks Given: 120
22
I maybe missing something but what light comes back on? . A new cam sensor fitted for what ?.
Throwing new parts at it randomly is just a waste of money. Get your friend to note the code that comes up if any .
There is plenty of fuel in the tank I presume
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
