Threads: 3
Thanks Received: 1 in 1 posts
Hi, today I noticed an orange triangle on top right of my dash, it appears a few seconds then disappears, sometimes it stays a bit longer. Any ideas what it means
Threads: 8
Thanks Received: 497 in 446 posts
Thanks Given: 301
31
Is there nothing in the hand book to give you a clue?
There's that many different styles of warning lights that tend to change from model to model it's hard to guess.
Threads: 8
Thanks Given: 301
31
20-02-2022, 08:31 PM
(This post was last modified: 20-02-2022, 08:36 PM by jj9.)
I would check the brake fluid level & coolant level as a first step.
EDIT...
I think it's a gear change indicator.... 3rd image down .....
https://www.manualslib.com/manual/778841...=38#manual
Threads: 3
That’s the one? Not sure what it means , change up with a manual gearbox, fuel efficiency? is it saying my gear changing is bad ?
Threads: 8
Thanks Given: 301
31
When the light comes on the car thinks it's time to change up to the next gear for best fuel economy, nothing happens if you don't do as it suggests.
