21-02-2022, 06:18 PM
(This post was last modified: 21-02-2022, 06:23 PM by LogiOne.)
Witam , zaświeciła mi się dzisiaj kontrolka poziomu oleju, dolalem bo stan minimum ale to nie rozwiązało problemu , dalej się świeci kontrolka i doszła kontrolka STOP
Silnik 1.9 D 71 km
Miał może ktoś podobny problem ?
Jakieś podpowiedzi?
Ewentualnie może wie ktoś gdzie dokładnie znajduje się czujnik ciśnienia oleju ?
Threads: 123
Thanks Given: 250
34
English please!
Hello, the oil level light came on today, I added it because the minimum state but it did not solve the problem, the light is still on and the STOP light has come
1.9 D engine 71 HP
Maybe someone had a similar problem?
Any hints?
Or maybe someone knows where exactly the oil pressure sensor is?
Hello, today the oil level light came on, I added because the minimum state, but it did not solve the problem, the light is still on and the STOP light is on
1.9 D 71 hp engine
Maybe someone had a similar problem ?
Any tips?
Or maybe someone knows where exactly is the oil pressure sensor?
Thanks Given: 39
13
Could coolant or brake fluid be low. These both put Stop on dash. Will have a look for oil pressure sender on our car in a bit
Thanks Given: 39
13
Oil pressure sender is above oil filter and oil cooler threaded into the block
Threads: 48
Thanks Given: 4
20
M49?
Are you certain it's OIL it's complaining about?
This model has an issue with the brake fluid. It needs to be topped up to MAX at all times. If it drops, he 'Stop' signal will activate.
