24-02-2022, 09:47 PM
(This post was last modified: 24-02-2022, 10:09 PM by chris@allpointsnorth.co.uk.)
Hi there,
Have a 2010 Berlingo and when looking for something completely different I found that the Blower Relay was not there.
There's no wiring loom either, just two of the cables wired together - another cable is loose and there's an Earth cable loose too.
I'd like to actually wire these into a proper relay, but can anyone let me know which cables connect to which pin on the relay? My Berlingo has two white wires (these are the two that are connected) one brown and an Earth. I've tried a bit of experimentation (I know, I know) but all I've managed so far is to blow the fuse so I'm clearly not connecting the cables correctly!
Frustratingly the heater works in this configuration, I have a relay ready to go, but can't find the right combo to get the relay to work, but I'd rather have a relay in place!
**I posted in the wrong place it's a B9**
Thanks!
Thanks!
