Drive shaft nut locking cap
Hi I replaced a front wheelbearing recently and couldn't have fitted the R clip properly on the drive shaft nut locking cap, so have lost the locking cap. Does anyone know where a replacement nut locking cap can be got? Its a 2003 Berlingo 1.9d.
A main dealer will be the easiest bet assuming you don't live too far out in the sticks otherwise a breakers yard should do the trick.
Live on an island so main dealer is not so easy and no breakers yard here either - so mail order is best.
Big Grin
Unlikely to come undone on its own, but put another R clip through the hole as it will stop the nut migrating off altogether. I seem to recall that some kits now contain a nut with a plain sleeve section that you just hammer into the slot on the shaft. I think I have a new one of those somewhere  - if you are stuck with getting the original type then let me know and I'll start searching for it ...... Big Grin
  • Islander71
I had a quick look in catcar.info & it looks like the part number is 3297-35
http://catcar.info/citroen/?lang=en&l=c3...BwbGllcj09
For some reason an online search comes up with this, which looks like the right part?
https://raceandrally.com/locking-nut
  • Islander71
(25-02-2022, 04:14 PM)cancunia Wrote:  I had a quick look in catcar.info & it looks like the part number is 3297-35
That looks like the part -many thanks.
Leaking windscreen or aerial
Last Post: Guanajuato
Yesterday 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
