Threads: 11
Thanks Received: 31 in 31 posts
Thanks Given: 3
7
Hi. I have apparently got an intermittent/erratic nox sensor 2 bank 1.
Anyone point me to the location of this sensor please.
Geoff
It's a 2018 1.5 Blue HDI
Threads: 11
Thanks Given: 3
7
Thanks for that, I was not sure if it was the first or second sensor. They are silly money!!!
Geoff
Threads: 18
Thanks Received: 8 in 7 posts
Geoff,
Did you get an engine warning light and text on the dashboard?
Threads: 11
Thanks Given: 3
7
First to light up was the diagnostic engine light, followed shortly by the spanner and a message on the speedo dash panel. It also defaulted the centre display to a map showing the nearest Citroen dealers.
I topped up with 7 litres of adblue and after about 5 miles all warnings disappeared.
The OBD fault code was P22A2 which apparently is a fault with: NOX 2, bank 1. Circuit intermittent/erratic.
Geoff
Threads: 18
Thank you for the info , it will hopefully be helpful to others who may suffer the same issue
