Is BOGE ever an original Citroen part?
Hi.   have just replaced a sway bar bush, it had the brand BOGE  on it.
Was this ever used as an original build brand/ part?
Steve
Sorry , it looks like no one here knows, I assume the sway bar is also known as the anti roll bar ?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(28-02-2022, 03:33 PM)brodfather11 Wrote:  I assume the sway bar is also known as the anti roll bar ?
Correct. But I also have no idea about Boge being an OEM supplier or not.
Thanks for the reply.
The reason I asked was I replaced the anti roll bar rubbers as there was a nasty clunking from the front.
My car is a 2006 model, I measured the bar diameter with verniers and it was 21 mm.
I put these in and the old ones had 22 mm marked on them.
The clunk is gone and I wondered if they had previously been replaced with the wrong size.
It seems that there are 21,22 & 23 mm rubbers available.
In any case should you need to replace these, check the size, the 21 mm ones were not readily available here for some reason
Steve
[-] The following 1 user says Thank You to Mudguard for this post:
  • cancunia
Handy thing to know .thanks
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
