Remote central locking problem
I have a problem with the remote locking on my 2006 M59 berlingo
It will lock from the key fob ok but will not unlock from the key fob
it will unlock with the key ok
when I try to unlock from the remote all that happens is the indicators flash as they should
Hope someone can help
Have a read through these threads, they should help you.
https://www.berlingoforum.com/thread-4356.html
https://www.berlingoforum.com/thread-16218.html
(27-02-2022, 02:05 PM)piginn Wrote:  it will unlock with the key ok
Does the whole van unlock when you put the key in the door (side doors, tailgate etc), or just the door you are putting the key into?
If the central locking doesn't work or just locks, it's mostly likely a relay on the BSI computer unit. There's a hatch in the passenger side cabin to access it. See the threads jj9 linked above for more info and also:
https://www.berlingoforum.com/thread-20968.html
And this is the thread that really helped me because it has photos of where to look
https://www.berlingoforum.com/thread-20457.html
FYI I found this job an arse ache. But the specialist won't touch the BSI unit so I was on my own...
[-] The following 1 user says Thank You to benoliver999 for this post:
  • jj9
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
