HELPPPPP, Dealer just want money money money money
Just wondering if I can get any help pleaseeeeeeee...
I have purchased a Citroen berlingo 19plate last year from a private dealer and still has 6 months warranty. The van has occured ad blue signal fault for couple times, and everytime I go to a citroen dealer they managed to put it back to normal (probably just a easy reset of sensor or something I have no idea about cars). They would then always find out something else and put forward a huge bill for us to pay (which we did in the 1st time).
However this time I take to Citroen Robin Day west london branch and asked them to check what exactly it is going on with the Ad blue system and that if they can fix it. (I raised a complaint about a member staff who wasnt polite to me), so they have it in the garage for couple days and ran through the checks. Next thing I am send a email saying that there is essencial work needing done and the bill is more than 1000pounds.  (Part of customers originaly requested work. add blue and engine light on ~requires new urea pump and dpf clean and regeneration
I am surprised they can simply put as customer required work as I wouldnt know what the problem is with ad blue signal and isnt it their job to check and advise the problem? what I also dont understand is the large bill they advised as this should be covered under warranty. I am just shocked and dissapointed with citroen. It is a reletivately new van with only 20K miles something, yet we have had so many problems with it. Not only it is annoying and time consuming for the fixings, but all too costy.
Worse still, they said after check the ad blue needs a new pump and further invesitgation... So that means it may have problem again in the future??
Any advise will be really appreciated,
PS. I have also tried to extend warranty the customer care said I can last year, but when i rang up now they said No. So they asked me to get it from ROBIN and DAY who also said you need to go to Citroen. It seems to me that all they want is simply money money money money money, so dissapointed.
Attached Files Thumbnail(s)
Hi, is your vehicle under 3 years old with less than 60,000 miles and full Citroen dealer service history?
You mentioned a ‘private’ dealer, do you mean a non Citroen dealer aka a different manufacturers authorised dealer or an independent dealer?
If it’s the later, are you trying to use the warranty they provided?
Which warranty is it aka what is the name/brand of the 3rd party warranty?
(02-03-2022, 06:03 AM)yingxue2022 Wrote:  Just wondering if I can get any help pleaseeeeeeee...
Hi there,
Adblue crystallizes and clogs the injector so the pump, which is part of the adblue deposit, doesn't work. Some people say that they have fixed the problem by doing the following:
- clean the injector and the catalyst (only the part where the injector is placed) To do this the doors must be locked and mustn't be opened. I have attached 2 pics, one of a injector and another of the catalyst
- empty the deposit of urea. Doors closed, don't open them
- fill the deposit with 1 litre of anti-crystallizer liquid (Xenum admax or similar liquid) and 5 litres of adblue from a new bottle (check expiry date before buying)
After doing all of this you have to connect obd(Amazon or Aliexpres) and with the app "Fap"(from Amazon store) delete the mistakes and restart the kilometres countdown (you might have to restart more than once). The liquid is supposed to clean everything while you are driving. Eventually the mistake will disappear and you will have saved a lot of money.
I haven't tried this method so I don't know if it will work for you. I would try the warranty first. You can have more information at the following Spanish forum: https://guiapsa.foroactivo.com/
[-] The following 1 user says Thank You to Mikelin for this post:
  • saskak
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
