central locking
Just  purchased my first 2011 Berlingo van, noticed the 12v cigarette lighter was corroded when i plugged in sat nav. After I cleaned and got working I have found the Central Door locking not working...?
I can hear the Relays working  UNDER DASH , when press fob and cab switches . but no clunks from any doors  locks.... ???
Checked the two  lock  fuses, are ok .
HELP...!!!
(02-03-2022, 06:49 PM)Dutt Wrote:  Just  purchased my first 2011 Berlingo van, noticed the 12v cigarette lighter was corroded when i plugged in sat nav. After I cleaned and got working I have found the Central Door locking not working...?
HELP...!!!
When you cleaned the cigarette lighter, did you disconnect the car battery? If you did you may need to perform a BSI reset to get the central locking to work correctly.
Timing belt change interval
Today 03:06 PM
» Replies: 19
B9 tailgate lock
20-04-2025 01:58 PM
Tie rod end bad almost every year
19-04-2025 10:56 AM
Water Leak Boot (tried a number of suggested fix...
19-04-2025 10:49 AM
AC Compressor Clutch
Last Post: tomhick024
18-04-2025 05:36 AM
Cruise control retrofit
17-04-2025 08:15 PM
Exhaust bracket
Last Post: timpascoe
17-04-2025 12:29 PM
Last Post: Mehal888
15-04-2025 12:57 PM
» Replies: 75
Washer Pump *Brand New unopened*
Last Post: Antdad
13-04-2025 05:47 AM
2.0 hdi clutch
Last Post: Martinez
13-04-2025 01:11 AM
