02-03-2022, 06:52 PM
Have a problem with my 2004 1.4i 55kW Berlingo. It's a 5spd manual. The speedometer doesn't work and as a result the odometer wont increase either. Everything else functions good.
So far I have replaced Front-Left ABS/Speed sensor. Also I have changed the speed sensor on the gearbox. Neither changed anything. Have also tried a different instrument cluster which didn't help either.
I used AutoCom and it gave me an Instrument Cluster error. Don't remember the exact fault code but the description was "Faulty speed data" or something like that. Another interesting thing to point out, is that AutoCom could not establish communications with the Brake/ABS module. However I have no warning lights on the dash about it. How possible is it, that the instrument cluster is not able to receive the ABS speed sensor data due to a faulty ABS module? And where would the ABS module be located?
