I've got a 2016 Berlingo van with the awful battery draining Teletrac Sat Nav system.
Does anyone know how to rip it out so I can actually leave the van for a week without getting home to a flat battery?
I know there's parts located behind the glovebox but not sure what to disconnect.
Threads: 75
Thanks Given: 223
164
I had Teletrac too and never had an issue with battery use, even during lockdown when the van sat for months. There should be a little black box behind the glovebox that contains a fuse for the Teletrac I believe but never had to find mine so not sure exactly.
Threads: 82
Thanks Received: 397 in 340 posts
Thanks Given: 172
21
09-03-2022, 05:14 PM
(This post was last modified: 09-03-2022, 05:17 PM by evdama.)
I have a 2012 van with teletrac owned from New.
No issues with battery draining until the battery was worn out a few years ago.
Replaced battery -resolved issues.
The van can be now left for a week in sub zero conditions then the glow plug has a good chew , but still starts instantly.
The new battery was ordered from Tayna using the VRN and I got the cold sweats when it arrived as it was significantly bigger than the one Citroen had supplied..
It fitted like a glove.
The original one was clearly under-specified.
That could be contributing to your problem.
