Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 8
14-03-2022, 12:05 AM
Hello,
Mid 2020 diesel XL auto that I’m very happy with.
Tried the ECO button recently. Not sure what it does?
Stay in highest gear? Freewheel (not sure if that’s possible!)
Does anyone know?
Thanks,
Craig
Threads: 2
Thanks Received: 55 in 51 posts
Thanks Given: 38
8
Dulls the accelerator pedal most importantly. Other energy saving features as well but irrelevant.
ex: 2003 1.4i cargo
The following 1 user says Thank You to boop for this post:1 user says Thank You to boop for this post
• MiloMc
Threads: 41
Thanks Given: 129
9
(14-03-2022, 07:43 AM)boop Wrote: Dulls the accelerator pedal most importantly. Other energy saving features as well but irrelevant.
My van sometimes tells me it's activated the ECO mode of its own accord. Maybe this is why I've been finding it sluggish?
The following 1 user says Thank You to notsofast for this post:1 user says Thank You to notsofast for this post
• MiloMc
Threads: 44
Thanks Given: 97
28
14-03-2022, 09:29 AM
(This post was last modified: 14-03-2022, 09:30 AM by Gryffindor.)
It may not be at all the same thing but the Volvo trucks I drive have an ECO button with separate + and - buttons. In these trucks it widens or narrows the range of 'free play' in the cruise control, i.e. max ECO means the CC does not kick in till your speed drops below (set CC speed - 5mph) and does not cut out until (ditto + 5mph), which has the effect of cruising on tickover downhill but losing speed uphill, whilst least economy works at (set CC speed) +/- 1mph.
In some other brands of truck the settings step at about every 0.6 mph, clearly kilometers relabelled.
TBH I always use the least economical setting because it gives me the greatest control over road speed, especially in 40 30 and 20 limits. My boss might fry me if he found out! He recently had all the trucks reprogrammed so that they are already on +/- 5mph at start-up, hoping that the newer drivers know no better.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
notsofast ECO mode on the dashboard of M59 & B9 means the electrical systems have been shut down to protect against flattening the battery, this is different to the ECO button on later vehicles.
• MiloMc
Threads: 41
Thanks Given: 129
9
(14-03-2022, 10:21 AM)Zion Wrote: @notsofast ECO mode on the dashboard of M59 & B9 means the electrical systems have been shut down to protect against flattening the battery, this is different to the ECO button on later vehicles.
Sometimes when I start up my K9 it says on the screen "ECO mode activated", even though I haven't pressed anything. According to boop's reply, this means the throttle response is dulled, so I'm wondering if this is could be one reason why the vehicle feels sluggish? Sometimes I press the throttle and nothing seems to happen, which I had put down to a sort of 'turbo lag' at low revs, but maybe electrical gremlins mean I'm driving in ECO mode without knowing it?
Threads: 75
Thanks Given: 223
164
Ah I forgot you have a K9 now, yeah could be.
Threads: 20
Thanks Given: 7
14
I used it a couple of times to see what it does and man does it cut down throttle response! It's like it cuts the power to half! Probably great on a run but day to day driving its really noticeable - i'll confirm once I finally get my van back!
The following 1 user says Thank You to Tree for this post:1 user says Thank You to Tree for this post
• MiloMc
