Threads: 80
Thanks Received: 391 in 334 posts
Thanks Given: 164
17
Vacuum?
The key may be brass and just laugh at the magnet.
Might have got to the cabin filters under the dash in the footwell but that is a b to dismantle.
Threads: 11
Thanks Received: 32 in 32 posts
Thanks Given: 3
7
Just forget it and get another key cut, it won't do any harm in the heater system.
Geoff
Threads: 44
Thanks Given: 97
28
Tip the van upside down and give it a good shake.
53 1.4i MS MPV RIP
53 1.6 MS Desire RIP
08 C4GP 1.9 VTR+
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
21-03-2022, 08:40 PM
(This post was last modified: 21-03-2022, 08:41 PM by Sol.)
The vent pipes all go to the lowest point, the fan housing under the dashboard on the driver's side. You might get it back.....but may be more hassle than its worth! Go to
http://www.catcar.info, select English language, Citroen, then put your VIN number in, go to the heating and ventilation section and the pipe layout will be revealed.
Threads: 80
Thanks Given: 164
17
(21-03-2022, 08:13 PM)Gryffindor Wrote: Tip the van upside down and give it a good shake.
Just turn up the stereo real loud
Drown out the rattle
Thanks Received: 5 in 5 posts
Thanks Given: 8
Many years ago I placed £6 in coins onto the dash of my Saxo, the very next bend those coins disappeared like the cruellest episode of Tipping Point.
It was costly and I learned from it
Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 3
I had this very problem with a fob for a barrier… I worked the heating vents and could hear it falling down the vents. It ended up at the bottom of the heating system. Had to strip the dash out (gear selector section, under the steering wheel, glove box) I took the time to change the pollen filter since I was there anyway! There’s a drip tray at the bottom of the matrix for the AC evaporator, Unscrew that and you can gain access to the flaps that control hot or cold. Mine was sitting the in against the AC evaporator. I could almost reach it but not quite… so In the end drilled a hole in the side of the box and put a magnet through. Got a bit of plastic from a bottle and glued in place, been fine ever since.
Recommend setting aside an afternoon for it as it might even stretch into the evening.
Three tips: 1. there’s a bolt for the drip tray at the very back against the bulk head, very awkward.
2. There’s a centre line dividing the passenger side from the drivers, so if you can’t see it on one side, it’ll be the other.
3. BE CAREFUL OF THE HEATING LINKAGES. I accidentally broke mine and it was a pain real pain to fix.
