Steel wheel options
OK, (probably) stupid question time...
I'm thinking of changing the wheels on my van for 15" steels, I want to just fill the arches out a bit so was thinking of getting a set banded by 1", I found these on ebay: 4 Alcar steel wheels 8475 6.0Jx15 ET18 4x108 for Citroen Berlingo Xsara Picasso 9008070284758 | eBay
Looking here: PCD Citroen wheels -Wheelfitment.eu | PCD, Offset, Center Bore, mounting and tire size data there are various wheels with greater offset than my current ones, so can I achieve the same thing with a straight swap? And if so, which ones?
As I say probably a stupid question but despite messing with cars for many years I never really got into swapping wheels.
My van: 2008 Berlingo 1.6 HDi Enterprise
I've not investigated for myself but have read numerous similar wheel swap posts on here over the last couple of years, try some forum searches, the search facility is a little tetchy (I find!) but all the info you want is here if you persevere!
Matt
2016 Multispace XTR BlueHDi 100 S/S Gris Artense Met
I agree that the forum search feature is incredibly picky.
Another more flexible way to search the forum is by using Google. For example putting this into G's search box exactly as it appears here (including any spaces or lack of them):
"wheel" "offset" site:https://www.berlingoforum.com/
will search the forum for any pages which include both the word "wheel" and the word "offset", whether or not they appear next to each other.
Changing the first bit to this:
"wheel offset" site:https://www.berlingoforum.com/
will now find pages containing the phrase "wheel offset".
Current: 2003 1.4i MS MPV - Lucifer Red
Prev: 2003 1.6 MS Desire - Blingo Blue
[-] The following 3 users say Thank You to Gryffindor for this post:
  • Matt Haigh, RattyCortina, Teep
(23-03-2022, 10:57 PM)Gryffindor Wrote:  I agree that the forum search feature is incredibly picky.
I have swapped out wheels over the last decade on my b9 van using stock from a wide variety of Citroen and Plugs.
All have ,at least, physically fitted with some types running closer to the brake caliperss than others.
There's also https://www.carlsalter.com/citroen-wheel-fitments.html.
Not sure if it's the same Carl as on Brassic.......
Offset can affect handling characteristics but as yours is a van I'm guessing that's not going to worry you too much.
Thanks for the tip on searching, I did try a search for '15" steel wheels' but drew a blank.
I'll have a look through the threads and see what I can come up with.
(24-03-2022, 05:36 PM)RattyCortina Wrote:  Thanks for the tip on searching, I did try a search for '15" steel wheels' but drew a blank.
What size are the existing wheels / tyres?
Whatever you do check that your insurance are happy with it!!
Wheels and tyres are classed as safety issues
Peter
Wheels are the standard 14", think all the 14's are 5.5J ? , can't remember the tyre size without looking.
Doing some searching I'm getting 2 different ETs, 18 and 24. To get what I want it seems I would need a lot less offset, so I don't think it's doable.
I'm waiting for a reply from my current insurers (Aviva), if they say no I will go with a specialist.
just put "wheel" in the search box and you'll get 21 pages of results. Not all exactly what you want but you may find something useful
Matt
My current wheels are 14" X 5.5", ET24 with 175/65 tyres.
To keep the same rolling radius on a 15" X 7" wheel it looks like I would need 225/45 tyres.
I would need zero offset wheels to put them 1" (approx) further out into the arches.
Gearbox
Last Post: Beady Zero Four
Today 09:04 PM
Protective Cover Extenso Cab
Last Post: Rftc101
Today 08:07 PM
Last Post: Grizz
Today 07:33 PM
» Replies: 1949
Rear panel of dash glove box removal
Last Post: woodywyatt
Today 05:15 PM
Centre console - alternative to factory fitted o...
Last Post: MartinCurtis
Today 04:36 PM
Hi All
Last Post: Zion
Today 03:19 PM
B9 fault code reader socket
Last Post: Zion
Today 11:52 AM
Hello
Last Post: oilyrag
Today 10:57 AM
Diesel viability
Last Post: LauraM83
Today 09:37 AM
Treading on accelerator & brake at same time
Today 09:22 AM
» Replies: 16
