Hi all I've got a 2020 950 XL Driver van but can anyone tell me how to replace the bulb in the third brake light with the camera assembly attached, I've undone the two bolts that secure it to the door and the housing is loose but it wont seem to come away from the door more than 5mm, it was a lot easier in the pervious model i had but that was just the brake light.
TIA
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
Can you get behind it from inside as there may be cable clips to undo as well.
Theres small clips that hold the unit in. Press them in and it should release
