Speedo and revs needle
Hi!
Can anyone check whether the speedo and revs needle in your berlingos vibrate or sweep after unlocking the doors and turning the ignition key from 1st to 2nd position(without starting the engine) ?
its normal all of the work vans do it.
(03-04-2022, 06:21 PM)5EAN Wrote:  its normal all of the work vans do it.
Thanks for your answer, but is it normal that they vibrate, sweep or both things?
Part of the computer startup self test I would say.
Bear in mind you can wind the Windows up after you've locked the doors with the remote control so it's fair to assume most electrics will still be at least passively live
Our Merc Sprinters sweep the needles on pressing the start button.
The engine won't fire unless you cover the brake pedal.
Actually the council guy who works in the park sweeps the needles too.
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
