How do I replace a damaged air vent?
I have a 2017 Berlingo panel van and it has a damaged central dashboard air vent. I've sourced a replacement but I can't find any advice on how to remove and fit the replacement without causing damage.
Assistance would be greatly appreciated.
I have done this job on a recent model Audi but not on my B9. I have a feeling they just pull out, but could be wrong. Normally the "hoses" attach to the rear of the hole in the dash, and the vent pushes into the end of the hose & dash hole.
Others may happen along who have actually done this. Or you can try the Haynes manual. If I remember, I'll dig mine out tonight and take a look.
FYI - Have managed it without causing any damage. 4 catches need to pushed from the inside of the vent (using a small flat bladed screwdriver) and the unit pulled out carefully as each catch is released. Finally there is one raised ridge at the very top that hangs on - a case of manoeuvring it out over this.
[-] The following 1 user says Thank You to dbritt for this post:
  • Teep
Brilliant, good info for others to follow.
Wiring Up Towbar Electrics
Last Post: Carl.1
Today 08:10 PM
berlingo 1.5 hdi problem
Last Post: vedran vk
Today 07:23 PM
3rd Gen Wiper Blades Supplier
Last Post: Mark604
Today 06:13 PM
New member M59 1.6 16v gasoline
Last Post: marcrbarker
Today 05:17 PM
I have been accepted for a job!
Today 03:23 PM
Very brief warning light
Last Post: Fell Wanderer
Today 02:46 PM
12v socket low voltage
Today 02:02 PM
2004 sunroof wanted
Last Post: DJP49
Today 01:35 PM
Air con light on
Last Post: Guanock
Today 11:09 AM
odometer going from mile to kilometres while dri...
Last Post: Mark604
Today 10:57 AM
