Threads: 21
Thanks Received: 49 in 45 posts
Thanks Given: 38
4
Anyone upgraded the rear speakers?
If I remove the rear square panel can I also remove/insert speaker without removing the wall panel (the larger one) ?
If you like gaming visit
GameForest
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
11-04-2022, 11:57 AM
(This post was last modified: 11-04-2022, 11:57 AM by Sol.)
From the pictures on Catcar, it looks like you can just remove the grilles and the speakers from outside the panels.
Threads: 21
Thanks Given: 38
4
the rear speakers are on the boot shelf not in the sliding doors, and I think the screws are from the bottom
GameForest
Threads: 21
Thanks Given: 38
4
I'm thinking to upgrade the rear speakers that are 5 inch (13 cm) with 6x9 inch, I have to make some measurements to check if the larger ones fit...
If they fit then I will cut the panel and install in place of the original ones..
GameForest
