Threads: 43
Thanks Received: 2 in 2 posts
Thanks Given: 28
Hi,
Does anyone know why my airbag warning light would come on after passing a MOT.
I have a 2002 berlingo M59 1.6 16v.
I would be most grateful for any help.
Squad.
Threads: 75
Thanks Given: 223
164
16-04-2022, 10:44 PM
(This post was last modified: 16-04-2022, 10:45 PM by Sol.)
Could be the seat wiring to the SRS squabs on the seatbelt female part. If the mot tester was tall and racked the seat back...could have pulled a plug apart.
Threads: 75
Thanks Given: 223
164
16-04-2022, 11:02 PM
(This post was last modified: 16-04-2022, 11:03 PM by Sol.)
SRS systems are picky. You're only talking 3 ohms per circuit in a good factory airbag or SRS squab.
• Squad
Threads: 39
Thanks Given: 1
4
I cut the connectors off on mine and replaced them with choc blocks, a bit awkward to get to and you need to make a note of the colours but I did it 10 years ago and not had a problem since
Peter
Thanks Given: 17
22-04-2022, 10:16 PM
(This post was last modified: 23-04-2022, 05:50 AM by CherryBomb.)
My airbag light comes on when I start to drive and beeps twice even though I don't think I have a passenger airbag.
Tried cleaning and re seating the connectors, may try changjng them to choc blocks as you have Peter.
Does anyone know where the green and yellow/brown wires go to when they go under the seat through a hole in the floor? Is it the central console or up to the steering column/dash board area?
