Interior lighting from side door
Hi
My interior lights in the back dont come on when I open side door but work when rear doors open.
Has anyone had similar problem. Or maybe a broken wire somewhere etc.
Does the front light come on when you open the side door, or no lights at all?
(22-04-2022, 02:29 PM)Zion Wrote:  Does the front light come on when you open the side door, or no lights at all?
Just tried it and it doesn’t.
Ok. Must be a faulty pin switch on the door which normally operates the lights. Have a good look around the door for a switch and see if it's stuck in the inward position or if a wire has come off.
The usual system was for a pin switch to ground the wire to trigger the lighting..on the Citroen it will be a signal to the BSI to turn the lighting on..
Last Post: BigVtwin996
Today 08:25 PM
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
