Threads: 18
Thanks Received: 9 in 9 posts
Update: There was a third screw not shown on the video to the right of the gear stick, removed that and then constructive brute force.
Looks like a activating pin has broken off in the mechanical part of the switch, but on testing it seems like it might be a back up as I can get the windows top go up and down but this is using the rubber pad as I have to get the switch back into the rocker and reassemble.
A tip.... when the plate is out put a piece of card or something to block the hole underneath otherwise things drop right down and to far for fingers or pliers.
blue tack on the end of a stick picked up the switch ok but the rubber pad is still to be retrieved, need a pea stick.
2009 1.6HDI with AC
Threads: 18
The lugs for the rocker switch were broken hence the wobbly switch, not fixable so ordered one of eBay for £9 and paid a fiver for fast delivery as against £64 from Citroen, exactly the same switch.
Now works perfectly.
Another tip which I can't remember where I read it.
To make life a lot easier remove the lower part of the surround (near to the console) one visible screw each side to remove the small side panel which then reveals a hidden screw each side, remove this screw each side and the whole surround comes out easy.
This enable the switch plate to be removed without a struggle.
As to the sprung screw plated several were a loose fit and kept dropping out, a smidgeon of blue tac between the plate and it stays in place while screw is inserted.
2009 1.6HDI with AC
