Threads: 4
Thanks Received: 135 in 131 posts
Thanks Given: 3
13
Could be that the mechanic rested the weight of the gearbox on the clutch cover release 'fingers' and damaged them, and this in turn can damage the release bearing. It certainly sounds clutch related, given your various 'tests'.
Probably needs the gearbox out to verify. good luck!
Threads: 2
Thanks Given: 6
Thanks for the info, oilyrag. Here's some more info about my experience with the mechanic, which may be relevant but I didn't put in my opening post as I didn't want to make it too long and boring to read:
The clutch had started slipping, and my usual garage was busy for a couple of weeks, so I found another garage to do it. When the work was done, the guy said that there had been an issue with (something along the lines of) a rubber bush on the gears had debonded? and that he'd effected a repair.
The noise described above was noticeable immediately on ignition. Also there was a lot of free pay on the clutch pedal, with the biting point being noticeably low. After driving it for about 2 miles, the gear stick dislocated, with it stuck in neutral and was impossible to put back in any gear.
Very long story short, the van was towed back to the garage, where, despite promises, it sat doing nothing for nearly a month before i recovered it and had it towed to my usual garage. They fixed the gearstick problem (it needed a new gear linkage, and another part) but haven't have time to investigate the clutch.
The remaining problems don't seem to affect the performance of the van - it runs ok, gear change is smooth etc.
Threads: 4
Thanks Given: 3
13
The de-bonding bit was probably around part of the gear linkage and the first garage had bodged it, and it failed straight away. Fixed by second garage. The clutch, with a low biting point and potentially the rattle from the same region, has also been repaired poorly. It is unlikely to do any great damage with the rattle, and you have the choice to use it as it is and get the most out of the replacement clutch or get the reliable garage to drop the gearbox out and inspect - it may simply be a damaged/broken release bearing and the cost will be reasonable. As with all clutch work, the labour will exceed the parts cost!
Threads: 2
Thanks Given: 6
Thanks again oilyrag, really appreciate it. I intend to sell the van soon (have recently bought a '15 berlingo), had it been a relatively easy fix then I would have had a go at it. From what you've described, it's likely to be hard work/money, so I'll leave it as it is, and adjust the asking price accordingly.
Threads: 39
Thanks Received: 358 in 317 posts
Thanks Given: 120
22
Apart from the points mentioned by oilyrag are the engine mountings OK, especially the lower one underneath the engine ?
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
