Threads: 6
Thanks Given: 2
hi all , i have just purchased a Sony stereo for my 2004 Berlingo. i have fitted with the supplied harness but its not saving my presets / clock / stations etc, do i need a different harness ?. thanks in advance for any help.
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
25-04-2022, 06:19 AM
(This post was last modified: 25-04-2022, 06:23 AM by brodfather11.)
I seem to recall a change of one wire position in the multiplug is needed. When you switch off it switches off the live feed which keeps the memory in the head unit.
Changing over the position ensures the live feed is kept but I cant remember which wire /colour , possibly red and yellow.
There have been a lot of posts on here about this. Try a search for " Car radio losing its memory"
Someone else will know the cure
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 123
Thanks Given: 250
34
IIRC, the radio wiring diagram is in the handbook for the M59, it should show the switched & permanent live connections.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• dixonp
