  • 7 Vote(s) - 2.43 Average
Advice on Tyre/wheel fitting and sizes
Hi all ive chosen my wheels just want to make sure with the advice from you guys if i will have any problems with fitting
Rims are 16 inch and correct fitment http://www.wheelbasealloys.com/16_Inch_D...eels__3237 will i beable to fit these on without any probs Confusedalut:Confusedalut:Confusedalut:
http://www.ebay.co.uk/itm/195-50-16-KUMH...2316d0f010
The website says that they will fit according to their "alloy wheel selector" so if they don't you can point to this. As a matter of interest, what is the offset of the wheels?
What tyre size are you looking at having?
I fitted some wider 15 inch tyres that were 195/65 and the added profile depth meant they can catch the body of the car at full lock. In hindsight I should have used 195/60.
Hence with 16 inch wheels, I suspect you will need a low profile.
Do you think 195/45/16 would be a better tyre then lads
That would only make 4mm of difference over 195/65/15 - would also be a hard ride.
Have a play around here:-
http://www.club80-90syncro.co.uk/Syncro_...ulator.htm
Might help you decide
Thanks Coco ur a Star its all back running again
It's tricky, as the 16inch wheel will add 12mm and the lower profile will reduce by 6mm...
If my experience is anything to go by, that might not fit.
Mine have caught the body a few times and the tyres were between 5 and 6mm tread. Your new treads will have the full 8mm on them.
Tuckers caught on full lock or the body as mines lowered 40mm at front and as im a mobile valeters i carry 250 litres of water this brings the rear down low
Eolys replacement tank
Last Post: Harrythephot
Yesterday 12:02 PM
Yesterday 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
