ESP/ASR system faulty
Hi, any help appreciated. Randomly getting traction control light appear. I've had it scanned today whilst the light was on with following results:
U1213 One of the parameters present in data stream sent by ABS/ESP is invalid
C0040 Brake pedal Sensor: Incoherence
Where should I be looking first?
Firstly, good luck with this. It might end up way beyond a bit of tinkering at home.
Anyway, brake pedal coherence...check both brake pedal switches are NOT made until the pedal is pressed and that both switches ARE made when the pedal is pressed.
Oh and they aren't mounted where you think (on the brake pedal) - but under the dome shaped cover in the passenger footwell...you might get lucky and one switch is stuck on, or has fallen off the bracket.
If this all checks out ok with a multimeter, then you're into canbus testing and abs sensors / wiring.
Many thanks, the mechanic ended up replacing the brake light switch and this seems to have solved the issue.
(02-05-2022, 06:35 AM)Sol Wrote:  Firstly, good luck with this. It might end up way beyond a bit of tinkering at home.
There are two brake pedal switches?
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
