Aux reversing light
I want to fit a small 6 inch or so led light to the rear of my van, thinking of taking the live from the reversing light but making it switchable so only on when selecting reverse and needing extra light, will this mod need a relay?
                       Cheers Wayne.
(25-04-2022, 06:37 PM)wayno Wrote:  I want to fit a small 6 inch or so led light to the rear of my van, thinking of taking the live from the reversing light but making it switchable so only on when selecting reverse and needing extra light, will this mod need a relay?
                       Cheers Wayne.
A small led might not put too much strain on things, but using a relay and perhaps an inline fuse is always good practice.
I wouldn't bother with the switch though.
There are regulations in place about the power of reversing lights/lights pointing to the rear and the LED that you are thinking of adding may well exceed them, esp. as the original fitment was non-LED. I think that your suggestion would fail an MoT.
(26-04-2022, 04:12 PM)oilyrag Wrote:  There are regulations in place about the power of reversing lights/lights pointing to the rear and the LED that you are thinking of adding may well exceed them, esp. as the original fitment was non-LED. I think that your suggestion would fail an MoT.
Which is why I want it switchable, which wire number/ colour is the reversing light on a 2013 Berlingo van?
You could just remove the light cluster with the reversing light on, put the gear stick in reverse and use a multimeter to check for the +12vdc wire and just tap in to that.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
