Hello
Can anyone help? I have a berlingo xtr+ van. Done about 40,000 miles. Drives fine when cold but as it warms up start to make rubbing sound, pulls to left then starts to vibrate. Had wheel bearings checked, had drive shafts sent off for refurbe but are fine, spoken to gearbox speacilist who says gerabox unlikley to be at fault.. I am at a loss has anyone else experienced this.
Threads: 5
Thanks Given: 4
21
Worth looking for a binding brake caliper - wheel hub will be hot, disc will take your skin off if you touch. If the symptoms arise and you can jack each corner up then it will show up as being difficult to rotate the wheel, although some drag will be present due to transmission.
Threads: 5
Thanks Given: 4
21
If it is pulling to one side that can be generated by (apart from brake!) steering/axle issue which should show up as unevenly worn tyres, but that wouldn't explain the rubbing noise and unlikely to vibrate any worse when the van is warmed up, unless the tyres are gripping better. A check would be to have the van on a 4-wheel alignment jig.
Alternatively if the nearside of the van is slowing relative to the offside maybe there is a gearbox issue - possibly an output shaft bearing or diff bearing. Maybe jacking up the nearside when it happens and rotating the wheel may give a clue?
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
28-04-2022, 02:48 PM
(This post was last modified: 28-04-2022, 02:49 PM by boop.)
K9 has electric power steering. Not sure what the OP has tho.
ex: 2003 1.4i cargo
