Injector 2 open circuit problem
Hi all
I have a recurring problem when the engine is under load, accelerating uphill for example.
Engine Rev will blip when revs are increased 2000rpm plus and either return to normal or go into severe limp mode. Turn the ignition off and back on, and limp is reset. I don’t even pull over to do it now, I do it before I lose any speed.
Obd states injector 2 circuit open.
Went to a mechanic who’s first question was “have you filled up with supermarket fuel” and for the last 3 months yes I have!
I have now run 2 full tanks of shell vpower with injector/fuel pump cleaner and the problem has much improved, but still occurs occasionally.
Could this be dirty injectors or a mechanical/electrical problem? Anyone had this problem before? Where do I start to solve this?
It’s a 2005 2.0hdi
Berlingo Multispace Forte, 2.0hdi, 2005.
Steel wheels are better than alloys.
You can test injectors with oscilloscope easy.
Scope can tell you if they are dirty or just bad.
For scope usage search the forum.
If you need more info shout...
Best regards,
brajomobil
Air filter box removal
Today 12:47 PM
Berlingo undertray
Today 12:42 PM
» Replies: 21
Yesterday 10:10 PM
» Replies: 21
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
