Adding internal handle to open rear barn doors?
Hello,
I have a 2019 Berlingo van (the older version, not the new one that is 2019 onwards) that I'm converting in to a tiny campervan. I'd really like to be able to exit the van via the rear barn doors, not just the sliding side door. Does anyone know if and how this can be done? It does look like there holes and a bit of moulding to the panel where a handle could/should go, but can't find anywhere with the part to fit.
Has anyone managed to make their doors open from the inside?
Ruth
Nope. Many have asked, but there are no parts available to achieve this.
would it be possible to add a switch that operates the lock?. My B9 up and over back door has one.
I would not feel safe if I needed to get out the back door quickly and there was not a way to open the door from the inside.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
It's been a few years since I had a " Barn Door " so have forgotten details - seem to remember a white square button that was pressed to open the door or am I thinking of my old C15 Van ??
Anyway maybe a photograph might job some grey cells ?
Either way there has to be a DIY method to sort this out.
Both my M49 and K9 barn doors have a handle so they can be opened from the inside.  (The M49 has no side door so it's the only way out).  I'm guessing the M59 will be the same as the M49.  Odd that the B9 doesn't have this basic feature.
The B9 van has side door inside handles. The rear barn doors have no internal mechanism with which to open the doors.
Have seen someone use a bog flush button to open the rear doors, requires drilling a hole in the correct place to essentially push the handle out from the inside
(28-04-2022, 01:48 PM)Root Wrote:  Hello,
Ruth
Please read my latest post on this:
https://r.tapatalk.com/shareLink/topic?u...source=app
Internal rear barn door release addition guide
Sent from my ANE-LX1 using Tapatalk
Yesterday 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
